ok...thanks245/40 and 275/40 or 35’s… those are a safe width over stock 235/265
I do for my track wheels…those shouldn’t rub tho…Anyone running 245/40/18 and 275/40/18s with x73 suspension? it'll lower the car about 1/3rd of an inch over stock sized tires. I already scrape often enough.. stock size Yokos are out of stock. I'm on 9" and 10" wide wheels.
Oh I meant I scrape the car on the ground (and curbs on track if I put two off) because its so low. the tires don't rub the car at all.I do for my track wheels…those shouldn’t run tho…
This will be fine. Also depends on what offsets you are running if you want to go wider.Oh I meant I scrape the car on the ground (and curbs on track if I put two off) because its so low. the tires don't rub the car at all.
With a 35/18 aspect ratio you're at a 0.65" front and 0.9" rear drop in ride height compared to stock sizing. That's too low imo, especially with X73 suspension.
I pulled the trigger on 245/40/18 and 275/40/18 Yoko A052s. They only lower the car about 0.25-0.3" from stock. I'm also on Titan7s, 9"s and 10"s. I'm hoping a little more meat won't overheat quite as quickly as a bonus.
Do you have 8&9” wide wheels? If so, you’d still be okay.. I think Apex is running 255/275 if I’m not mistakenI'm thinking about doing the same, any issue with increasing by 10 on stock wheels? Thanks
imo a 245/275 is starting to get a little wide for 8/9” but people still run them. Also depending on the tire… sometimes blocky tires on a smaller rim looks even blockier…I’m believe so. They are the stock 5 spoke 18” wheels. Seems like one size wider works. Thanks.
The rack doesn’t have them? Or are you asking if they’ll fit? Yes they’ll fit on those widths however up front you’ll probably stick out a little because you can’t get enough neg camber with the oem LCA’s…I have 245/285 but I’ll go 255/295 nextAnyone running 255/40/18 front w/ 285/40/18 rears on 9"/10" wide wheels? I'm hunting for One Lap of America tires so need a Michelin PS4S or Conti ECS type tire.
I'm looking for feedback on fitment. That's good. I'm running GT3 LCAs and have about -2.6deg of front camber so outta work it sounds like.The rack doesn’t have them? Or are you asking if they’ll fit? Yes they’ll fit on those widths however up front you’ll probably stick out a little because you can’t get enough neg camber with the oem LCA’s…I have 245/285 but I’ll go 255/295 next
