Top Gear UK 987.1 Equal Length Performance High Flow Decat Header Set - No Longer Available
I have a set of Top Gear UK Headers for 2005-2008 987.1 Porsche Boxster/Cayman models for sale. They are Direct Fit, 304 Grade Stainless, TIG Welded. They have been used less than 500 miles and are in excellent shape. They have already turned a nice golden color. Included is a set of Stainless Steele Studs and Stainless Nuts. Four of the Nuts have been modified, basically the base has been ground for clearance on the outer four header flange mounts. If you use the stock stud/nut nothing has to be done. I am also including 2 sets of Header Gaskets, stock and what came with the Headers, Muffler flange Gaskets, Hardware and O2 Sensor Spacers. If you re looking for an affordable, performance oriented, high quality option to what is on the market today, this is it.
List Date: 3/21/2019
For more info, click here to view the original listing: Top Gear UK 987.1 Equal Length Performance High Flow Decat Header Set
This item is no longer available.
