Hi There
Just got a set of new Front lower control arms, they look like a Tuning Fork (Not the other Coffin shaped arm.)
Does someone have the Torque specs for the 2 bolts .I believe the Cayman and Boxster front suspension are the same.
Mine is the 06 Boxster.I checked the web and found some numbers for an 986 but the front end looks slightly different.
The 986 looks like 118 lbs for the bolt close to the wheel and 89 lbs for the bolt at the other end that has the Bushing in the arm or fork.
There are a few other bolts that have to be loosened also to get the old arm out, if u have those also.Thx
