After the 2nd and now successful re-build of my front calipers w new pistons I measured my track pads (PFC 08's) and found uneven wear. At one end of the pad, it is 7.5 MM of material left and at the other end (going left to right), there is 8MM left.
Makes me think that if I try to continue using them, since they are effectively slightly slanted, the contact of the pistons will also be the same on the backing plate. This would seemingly cause a lack of uniformity of the orientation of the piston within the bore which could prematurely wear the bore as a whole. I say this because the pressure exerted on the backing plate via the piston would be via the edge that is touching (since the pad orientation is not flush but slanted)
Does anyone have an opinion on this matter? I already bought a new set of pads but wanted some of you to challenge my logic.
