Planet 9 members, I'm making this thread to explain something to a fellow Cayenne Owner.
Hope this helps.
It's the green box in the first picture and the #4 in the second picture.
There is a heat exchanger that sits atop the transmission. Two paths run through it. One path is transmission fluid and the other it coolant. The transmission fluid runs thru a front air cooled radiator then again thru the heat exchanger that site stop the transmission. So there is coolant that runs towards the transmission, or that little box that sits on top of the transmission.1999Aero911;18065388 said:Upon researching the issue someone said it was related to cooling the transmission, but I am not sure that is the case since its coolant and not ATF. BTW the other side valve on the drivers side is a lot easier to get to and is actually in the wheel well so all you have to do is remove the liner.
Hope this helps.
