The OE switch panel comes with the Suncoast kit and is likely the difference in labor. I did mine over a couple days and 7-8 hours seems about right for the complete install. The PSE kit has an electronic vacuum change-over valve that mounts on top of the engine and controls the rear valves via the console switch. To do the full console switch panel and wiring, the drivers seat and all panels from the rear trunk to the backs of the seats must be removed to run the wire from a relay at the passenger rear tail light area to the rear electronics controller that resides under the drivers seat. Then the dealer must program the button.So it seems like the quotes you all are getting to install PSE are for 7-8 hours of labor? I am trying to figure out some discrepancies here. When our dealer network (ourselves included) quotes an install of a Soul Performance Products Valved Exhaust for a 981 Boxster S, they quote about 5 hours including the install of the the exhaust itself, the valve controller and all of the vacuum tubing necessary. Maybe the difference is the switch panel? When we do it, we link the valve controller to the homelink so there is no need to install a new switch.
