i had meth injection on my STI b4 , and it does more than what most of people knows. i don't know why ppl do water/meth instead of full meth ( which is what i did ). the bigger the turbo you have, the more increase you should get, especially for people socal with the shitty gas here. however, for N/A, i don't think it's worth it to do since u are not making much gain out of it even tho it should only cost you around 400-600 for the kit.
first of all, other than acting as a booster, the meth also keeps the engine runs cooler (which is what we want) and the new tech of meth kits are actully pretty safe. the new cooling mist kit has a flow valve and pressure gauge , with a controller ..etc, so you can set it for ex. min spray at 5lb of boost and max at 17lb , and for high boosting cars, u won't be consuming any meth while you are just cruising on the freeway. My STI was making 450awhp without meth, and it's due to the low "over rated" 91 octane, but with meth injection, i was able to put down 520awhp for daily drive with 25lb of boost,so if i ever turbo my CS, meth will be a most for me, the only thing is the in CS, the trunk is connected with inside, so i might smell it....
