I posted as thumbnails, let me see what's up
I posted as thumbnails, let me see what's upFor some reason, can’t open the pictures…love to see visuals of your alpine head unit after install.
Yep, I installed this exact sump over 5 years ago. Seems to work well, but the return oil sits on top of the windage plate and shoshes up the walls into the bottom of the AOS. I finally had the Porsche Motorsports AOS installed, and no oil downs after that.LN Engineering 2qt Deep Sump & Baffle Kit installed on the car today. Getting ready to do some more heavy tracking with the car. Once the gasket cures overnight, filling up with Red Line 5w50 for 3000 miles before a switch to Motul 8100 or 300V.
Hi Apex, thanks for the detailed response! I am friends with DinkyHatchback irl and was following along with the thread regarding his blown AOS and 300V. I am planning to make the switch over to 300V at my next oil interval (3000 miles) - I had already ordered my Red Line by the time you had responded to him with the suggestion to use 300V.Yep, I installed this exact sump over 5 years ago. Seems to work well, but the return oil sits on top of the windage plate and shoshes up the walls into the bottom of the AOS. I finally had the Porsche Motorsports AOS installed, and no oil downs after that.
I would also recommend the LN spin on filter as it provides much less back pressure to help prevent #6 rod bearing scaring. George at LN can set you up. They also sell their track filter which is just a screen that you wash out when changing to street oil.
I would also add a Wavetrac LSD to your transaxle. Its a great product without clutches and it certainly works in the wet and dry providing added traction without any snap over steer effects after the apex. The slider wave is what locks up and transfers power to the planted tire.
A 996 heat exchanger will fit and adds about 40 more square inches of oil/water heat exchange.
I also added Sprint Booster to open the throttle body quickly as the two tire thrust certainly can handle this engine's limited hp. I'm using Bridgestons new track tire RE71RS as well which sticks well and has good longevity.
Looked into the sprint booster - my car is a sport chrono car and I already feel like the sport mode throttle response is a bit annoying to daily drive. I'm unsure if that mod is right for me but it may be best when coupled with the LSD. Is there any benefit of going with Wavetrac vs. Quaife? I know both manufacture LSDs for the 987.Liketheboss- Sprint Booster is an electronic aid that plugs into your throttle peddle. It open the throttle body much more rapidly to mimic the big brother 911 group, Porsche downplays the Cayman to make sure the 911 is faster by using this sort of programing. Look it up on the Sprint Booster web site. Not every owner believes this stuff, but with the LSD, I certainly can use more thrust without any tire spin.
The Porsche Motorsports AOS also sucks the addition oil from the heads. 987.1 need this suction as the 9A1 motors have 4 head oil pumps, while the 987.1 have 2. So the Motorsports help with this oil being collected in the heads on high G corners. Not sure the Ultimate AOS sucks the oil out of the heads like the Motorsports does.
Can you explain how the motorsports AOS would manage to suck a meaningful amount of oil from the front of the head? Isn't the AOS located towards the rear of the motor? And if it does suck oil up, vacuum is pulled via the intake so wouldn't the oil go there instead of back to the sump? I always thought the AOS was supposed to separate oily vapors from the air before it got pulled into the intake system, not act as another scavenge pump.Liketheboss- Sprint Booster is an electronic aid that plugs into your throttle peddle. It open the throttle body much more rapidly to mimic the big brother 911 group, Porsche downplays the Cayman to make sure the 911 is faster by using this sort of programing. Look it up on the Sprint Booster web site. Not every owner believes this stuff, but with the LSD, I certainly can use more thrust without any tire spin.
Thanks for the info, both about the pistons and the AOS. One thing I'd like to add is after reading Charles Navarro's paper on Ni-Sl cylinder walls, he describes Moly as a better version of ZDDP. While he says both are helpful in tandem, I gather that moly is what we specifically should look for since ZDDP is ill-advised. Good thing 300V is full of molyDinky- I'm not a genius here. I just take the facts and analyze the results. Porsche should not have developed this cylinder wall matrix with an plastic like skirt coating on the pistons. Whats even more interesting is that 996 motors did not recieve the same treatment. So, to the ZDDP issue, well I looked up this additive and what it brings to the engine cylinder walls...
Oh wow, I guess it's this lower line ( 987-107-947-00-OEM ). Didn't know this ran to the head, interesting! Maybe that large diameter piping his what helps with oil draining out of the head. Ill make sure to add that to my car when I upgrade my AOSNo, I'm talking about the vacuum lines that go to the heads. This attaches to the Plenum with two hookup and the single with the two lines attaches to the AOS.
Are they oil filled?Changed the inner/outer CV boots on the drivers side. and then noticed the passenger side engine mount appears to be failing/bleeding. Guess I'll order them next.... View attachment 285828 View attachment 285829
Yep. Those are the transmission motor mounts and they are both hydraulic.Are they oil filled?
Wow, small world. I just did my trans motor mounts and CV axles a few weeks ago. Consider yourself lucky, my axles seized in the hub so I had to pull the entire knuckles off to the boots. Not fun but worth the preventative maintenance so I don't break an axle.Changed the inner/outer CV boots on the drivers side. and then noticed the passenger side engine mount appears to be failing/bleeding. Guess I'll order them next....
