What did you do to your 987 today?
1294153 Views 9188 Replies 1201 Participants Last post by  guzzista
A popular VW enthusiast site has a similar thread. Post up what you did to your 987. Types of things to post could be cleaning, maintaining, modifying, piloting it around a track, etc. Post pics if you can. This thread can inspire others to do something similar. I'll start...
Reactions: 1
9141 - 9160 of 9189 Posts
^^^ that's a handy addition. Before I got my QuickJacks, I put one of these on and used it a lot. Recommended.
Just back from the track. Ready for a good wash, with a very handy red jack point in the rear. Milltek stainless exhaust, Hoosier slicks and Titian TS5 forged wheels, a LN/BRS skid plate and OEM red brake lights.
Vehicle registration plate Car Tire Vehicle Wheel
Reactions: 3
ok, this question from a novice... is that what that red component is on the underside, just ahead of the tailpipes? Aftermarket?
I have a red one of these on my Cayman, too, and I will admit, I didn't know what it was! Do all Caymans have this? (Maybe just not red ones?)
Yes that is the red part that you see. It’s so you have a good spot to put a floor jack on to lift the *** end of your car. It is an aftermarket part and was probably bought from Fabspeed.
Reactions: 1
tiiger- If you want to use the red lift point, be sure your 5000 lb floor jack is stable on the concrete flooring to lift the rear up high enough for rear jack stands to be placed under the rear quarter panel in front of the wheel. You can feel the indent where the rubber jackstand spacers should go. If you only want to lift the rear, you may want to place somesort of block in front of the front tires. I use this jack point to change the oil and filter with the jack stands in place and front tires blocked.
tiiger- If you want to use the red lift point, be sure your 5000 lb floor jack is stable on the concrete flooring to lift the rear up high enough for rear jack stands to be placed under the rear quarter panel. You can feel the indent where the rubber jackstand spacers should go. If you only want to lift the rear, you may want to place somesort of block in front of the front tires. I use this jack point to change the oil and filter with the jack stands in place and front tires blocked.
Does that fit into the two bolts on the tri-point? My diffuser bolts up at that point and wondering what that looks like before I buy one… snap me a pic when u can… thanks 🙏
From Fabspeed web site. Just order the 987.1 model from whoever you trust.
Motor vehicle Automotive design Automotive tire Car Automotive exterior
Reactions: 1
Anyone know the dimensions on that Jack point? As in wall thickness? They seem awfully expensive for a couple of inches of steel box section
You have to look at the failure rate. The box fails, you car could slide off the jack. The thicker walled box, the better.
I understand that, hence asking the wall thickness of the steel. There would be no recourse should it fail here in the Uk as they are not sold here from what I can see. If someone knows the wall thickness of the box section used I’d be very grateful.
thanks
That billet aluminum is exactly the right way to go. I do have the older pressed style which works fine, but the monoblock billet is much better as the weight of the car is put on that single point until the jack stands can be placed in front of the rear wheels.
How do I get my underside of the car clean like in the photo above. Are there some peanut shell cleaners around that do not use liquid to clean off years old road grime?
Reactions: 1
These look cool… my diffuser slides in between those two bolts of that V shaped aluminum piece so I’m sure that’ll still accommodate … thx for that shot
Fitted a new clutch and flywheel today. The clutch is super light now, very easy to shift gear, a much improved experience.
I bought the car three years ago with 30k miles, and just thought these cars had a heavy/aggressive clutch. I’ve also spent years trying to improve the shift feel, trying lots of shifter options and now with the full numeric set up.
i have no doubt the poor shifter feel when cold is linked to the clutch.
anyone who has a heavy clutch, poor shifting when cold Etc, and think it’s normal.. it’s not.
these cars didn’t leave the factor like that.
Reactions: 1
I purchased two GT3 brake ducts for my Cayman S. Purchased online and they arrived within three days. Unfortunately, they sent me two left side ducts, one of which had a sticker affixed to it with the right side part number. 😫
  • Wow
Reactions: 1
I stopped and filled up with top tier premium fuel. I know it may not seem like much, but before I started exclusively running top tier premium (not all premium is top tier) I would get misfire codes that would appear and then go away. I haven't gotten one in months.
Wheel Vehicle registration plate Tire Car Vehicle
Reactions: 2
Agree … not sure which brand is best, but I only use BP or Shell in my old 987.2 BS … she only likes the good stuff and will sputter on Speedway … she’s a bit of a diva when it comes to her fuel.
Reactions: 1
I decided to take my 987.2 to Williamsburg to clean out the pipes for a few days.
Reactions: 1
Same here my Porsche is an absolute diva. The real important part is having this logo on the pump.
Font Circle Brand Logo Graphics
Reactions: 1
