1 - 13 of 13 Posts
The white circle next to the flash spot. It is located on the driver's side window on the outside. It is located about 1-2 inches from the top and about 6 inches from the back edge and is about 1/4 inch in diameter. It easily rubs off, but it seems to appear every now and then since I've had the car (2012 CS). Can't seem to figure out where it comes from. Is it from when I open the window? It's been driving me crazy for years.
Thanks.
I haven't ever noticed the spot on our 2012 CS, but it shows up regularly in the same place as yours on our 2011 911. With all the other grease smears that show up on the windows of both cars, especially in the couple of days after a wash, it doesn't bother me much.
I have this on my 2012 CS, too. I always assumed it was a mark left by some kind of rubber device inside the door to stop the window rattling when it is down. That's a pure guess, though.
Most car makers use robots to place window glass. The robot arms hold the glass with suction cups. Sometimes those suction cup imprints show up on the glass. I see those suction cup marks on the back window of my wife's Mercedes ML. I've cleaned those windows many, many times and the cup marks still show up under the right conditions. So it could be something like that.
I don't think it's a suction cup mark, as this is a rather small mark - about the size of a shirt button. I initially thought it had something to do with the way I close my door using my left arm, but it's not.
I have to go with something that may be holding the glass inside the door. I never noticed this on the passenger side though. Although that window is rarely put down.
Definitely coming from inside the door when the window is lowered. I also suspect its a type of cushion to keep the window from moving/rattling when it's down. I've experimented and if I don't put my window down, it doesn't appear. When I do.....like magic. There it is. If it stops rattles, I'm OK with it.:cheers:
I have seen the same 987 and 981. I agree, it seems like the imprint from a pad that keeps the window from rattling when down.
Discussion Starter #8
Thanks. After reading the above, I agree. It's just that over the years, I've never been able to correlate it with any particular thing. I guess I'll just try to keep track next time.
The suction cup marks that I see on my cars are bigger than a silver dollar so that mark is probably something else. I like the cushion explanation.
Have the exact same issue... it's something inside the door that holds the window. The mark is some grease from it... only solution is to rip the door apart and clean the thing off. Or, just clean your window from time to time
Got it on my CGTS too. Wipe it off and it comes right back. Looks more like a thumb print on mine, though.
Alien crop circles
I sometimes get crop circles and the occasional wave pattern on my windows. most irritating esp. when it rains.
Improved since I cleaned the windows and door rubbers but sometimes those darn aliens that hide in the door come back down and draw them again! :)
1 - 13 of 13 Posts
