Hi gents,
What tire pressure PSI do you run on your 981S?
My dealer set my 19" Cayman wheel/tire to 33 psi.
However, I just check the drive-side door sill, and the sticker there say 29 PSI for front and rear.
Just curious - what tire PSI do you all run?
Thanks.
Next Porsche: 2022 992 GT3
I pressurize my tires according to the door sill instructions. This is what the manufacturer recommends and not a Sales Associate (who may have just transferred from Toyota). :) This is the cold pressure anyway.
Of course, if you track your car or store it then I would have a different opinion.
This is dependant on the wheel sizes and the tyres fitted.
For 20" Wheels and P-Zeros its 33 PSI. Most likely why the dealer set them at 33.
If you have a different configuration then you need to set for the correct wheel and tyre combo.
What does your TPMS recommend? I assume the dealer set the correct Wheels Size and Summer / Winter settings?
I try to run 39 hot, which means about 35 cold on 20" wheels.
Is that for track work or on the street?
I'm running about 30 front and 32 rear with the comfort setting engaged so the TPMS doesn't get too excited. Maybe I'm too low but that is where the dealer set them.
