1 - 17 of 17 Posts
Argh!
What's wrong with my car?
I get a squeeking/squaking from the front passenger corner over bumps and in corners. And as you see in the video just from pushing up and down on it.
The car is 3 years old with 57,000 kilometrs. Never tracked hard or abused in any way.
I took it in to the dealer and they said it was the lower control arm which they replaced under warranty.
Problem still there, still exactly the same.
Obviously I'm going to take it back in on Monday, but what do you guys think it is? And why the heck couldn't the main Porsche dealer in Toronto fix this the first time?
So annoying. Sorry, rant over.
FYI For some reason, I can't load the vid.
Squeaks area a pain in the rear to figure out sometimes. I had to return to the dealership 5 or 6 times to get mine fixed. Mine is at a different location than yours as mine turned out to be the small rear driver side window.
Good luck!
-Moto
Good luck!
-Moto
Video link fixed for you.
I have had the same squeak on past vehicles although never on my cayman. The problem was a squeaky rubber bushing almost every time. I found a polyurethane safe oil and lubed it up and the squeaking was gone. Hope that helps.
Wow! If they can't find that one they must never find any types of squeaks or rattles. I would think from the sound and the ease with which you can demonstrate it that they'd find and fix it in a heart beat. Obviously take it back and don't drive away again unless you can no longer reproduce it as you did in your video. I'd even consider escalating the complaint to dealership upper management.
I think the flux capacitator is leaking neutrinos. That is the sound they make upon colliding with the rubber tire as they escape the capacitator each time you push down on the fender. You may need to replace the tritanium gasket. You are welcome to tell the dealer this was my suggestion. ;)
do let us know what it was, i've got a similar problem
Argh!
Discussion Starter · #14 ·
So I took it in this morning but the squeak was gone! Couldn't replicate problem!!! Argh.
I showed them the video and they just went "Huh."
I told them the theories from this thread, but the guy who replaced my control arm says, nah it's not the bushings or sway bar, he thinks if might be the shock/spring but he thinks it only happens when it gets hot.
So now I have to drive around till it squeaks again and then bring right in.
This is so annoying.
I think I'm going to quit my job, train to be a master Porsche technician buy all the specialized tools and learn to fix my Cayman myself.
congrats that the squeak was gone but it is like a nightmare waiting to happen again. BTW great demo video (you made your point) ;)
at least you have several opinions here in case the squeak come back again:eek:
cheers
rex
1 - 17 of 17 Posts
