Discussion Starter #2
Stocked up on more of our high quality CNC machined hubcentric wheel spacers! Order a set today! Link below.
Available in sizes 7mm, 12mm and 15mm.
Schnell Autosports - Wheel Spacers & Lug Bolts
To place an order please give us a call at 1888-978-9899 or visit our website.
If you have any further questions, feel free to ask us on our contact page!
*Prices do not include shipping or any applicable taxes.
I highly recommend stud conversion if you use different spacers and rim widths/offsets. Eliminates remembering which lug bolt combo goes with which specific wheel/spacer combination.
If you track the car, make sure the studs are inspected yearly.
V6
Discussion Starter #4
Schnell Autosports offers a lug stud conversion kit, which converts your stock lug hole/lug bolt setup to a more familiar (and easier to deal with) lug stud/lug nut setup. Our conversion studs also feature an unthreaded portion at the end of the stud, to allow you to easily guide your wheel and lugnuts on without risk of cross-threading or damaging the threads on the stud.
The conversion kit comes in two different options:
* 45mm kit, for those of you running no spacers, or our 7mm spacer kit
* 45/59mm kit, for those of you running our 7mm front/12mm or 15mm spacer kit
Both kits contain 20 conversion studs and 20 ball seat open ended lug nuts.
Find out more information at Schnellautosports.com or give us a call at (888) 978-9899.
Schnell Autosports 7mm Hubcentric Spacers - Set Of 4
One set (four 7mm spacers) of high quality CNC machined hubcentric wheel spacers for your car. Widen your track for better traction and cornering, or to provide more clearance for wider tires, or to just make your car look better!
Wheel spacers are available with either extended wheel bolts, or with Schnell Autosports' lug stud conversion kit for proper and safe installation. Both options include countersunk rotor screws for securing the 7mm rotors to the hub
Bolt pattern: 5x130; Hub bore: 71.6
Check out our quick and easy installation guide here.
Discussion Starter #6
Schnell Autosports 7/15 Hubcentric Spacer Set!
Both options include countersunk rotor screws for securing the 7mm rotors to the hub.
