Have you shopped around?
It's actually a very simple one, and in my experience, unreliable. I threw it away. That's exactly the same Ferraris and Lambos use. Have a much better CTEK (mus4.3), with a desulfation cycle, but only use it for heavy desulfating, as it's also prone to errors. The one I use now is an Optimate-6, which also includes a light desulfating cycle. No errors at all in several years I've been using it. And that's all you need to maintain a new battery. And most importantly, it charges a flat battery (something Battery Tenders and CTEKs can't do), and it goes up to 5A, which is a lot quicker than the others as well. But to each his own. By the way, all of those chargers work best when directly hooked to the battery. Therefore, I always install a pigtail that way, and use the Optimate. The additional benefit of that is you can connect an air compressor or any other device directly to the battery via a SAE connector. And in the case of a Porsche, being able to open the frunk if the battery goes dead without having to jump it from the fuse box inside. Hope this helps
