1 - 20 of 33 Posts
If you order the optional XM radio from the factory, does it tie into the stock antenna or do they stick an extra dorky looking antenna on the back?
Low profile shark antenna on the roof.
dave-t
Factory XM antenna is a small truncated pyramid about 2" square, at most 1" high, just in front of the back hatch (at least on the Cayman). Painted to match body color. IMHO, it looks much less obvious than the shark fin you see on Beemers and others.
Reception is fantastic, integration with PCM 3.0 nagivation (oops...navigation) is well done - traffic info updates route regularly during long trips.
Thank you for the great information!
So does this antenna come standard on all Caymans, or just those that have the XM option? Also, is XM available as an option by itself, or do you have to also order PCM?
In order to have XM I believe you have to get PCM 3.0 and XM as a factory order option. Xm can not be added after taking delivery of you car at the dealership.
hope that helps,
dave-t
I'm curious to know how good the XM sound quality is and the cost of the service monthly....
I forgot to mention I also ordered the Bose. The sub is stuffed and audiopilot, surround and linear are left on by default. I turn the bass to 3+ for the XM and leave fader and balance neutral.(Mostly listen to smooth jazz and light rock aka The Bridge) With these settings I think the XM sounds great but that's just my opinion. As you might gather I'm very happy with all these features and would order again. :cheers:
PS: XM Canada is about $15/month
Discussion Starter · #12 ·
That's a bummer--I'd like XM but don't want to get the pricey PCM, guess I'll have to do w/out. I'm going to get the aux. input option (cheap and you can atleast play an ipod through the sound system) and I'm guessing the base cd player will play mp3 decoded cd's so that should help as well
Apologies on hijacking the thread but thought I would ask here rather than starting a new one.
Where is the OEM XM/Nav antenna on a Boxster?
It is located in the middle of the clam shell as a small turtle shaped pod. Yes, this is an accurate description, but if you aren't familiar with the boxster then not too helpful... :).
Just above the third brake light:
Thank you for the info.
Northeast Member
How is reception with the xm? Mine is terrible! It goes in and out quite a bit and even gets some static from time to time
I've got serius in my other vehicle and the only time I loose reception is under a bridge or in a parking garage. The xm drops out in the shadow of a tree! Is this how xm is or is there a problem with my unit or antenna?
On Gen 1 cars (PCM 2.1) it is possible to add the Cayenne XM unit and place the antenna under the wiper cowling. It works quite well. I do not know if a similar effort could be accomplished with the current PCM units.
PCA member since 1998
My 06 CS came with one of these. The reception is not great where I live - cuts out from time to time, but the sound quality is pretty good. Not sure if I'll re-subscribe...
Northeast Member
My reception is actually getting worse. I am actually getting static on some of the channels now. I've never heard static on my Sirius radios. I wonder if it an antenna or head issue...I guess I'll have to get it in to the dealership.
1 - 20 of 33 Posts
