I just noticed that when I pull gently on the handle to open the door, my passenger side window doesnt lower like it is supposed to. It makes the noise like it wants to lower it that .5 inch but it doesnt. Anybody experienced this before? Is it the door window motor or is it the switch that deals with it? Thanks!
For whatever it's worth, my passenger side window lowers a lot less than the drivers side when you lift the handle. As long as it clears the rubber molding you should be good. If it doesn't and the door is difficult to open because the window is still behind that molding, then an adjustment can be made. Again, it's described in the manual and if you didn't get one, there is one for downloading on this site. If that doesn't work then a dealer visit may be needed. Good luck.
