1 - 9 of 9 Posts
AMG rep. 19x8.5 5x112
They are 19'
will this affect performance alot?
How do you guys think they will look on a cayman? I know they are originally for mercedez, what do you guys think? thanks
I think they are good looking wheels and would look great on a Cayman.
Whether or not they will fit, however, will likely be a question of rim offset. A quick search of this site will produce several threads discussing "wheel offset", and should help to answer your question. If that doesn't do the trick, a call to your local dealer or Porsche tuner should take care of it as well.
They will not fit. The bolt circle is not compatible. Porsche bolt circle is 5 X 130. The information is in the picture on the box.
The offset, which is also shown on the boxes, is inadequate - they would stick out too far. You can learn a lot by using the Search function on here.
thanks everyone for the input. dang that sucks.. thought they looked real nice too. i wanted these originally
997 Turbo
*EDIT*
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390157357648&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=6f1752081260a0437367abf7fff54bc4&rvr_id=&ua=%3F*I7&itemid=390157357648
these will fit on a cayman without any spacers?
do you guys think these replica's will hold out well for standard driving? is there a specific place i should be getting them? i kind of don't want to pay too much since they are going to be replica's
Is there ANYWAY i can get
5x114.3
20x9 +30 (2" lip) Falken FK452 245/35/20
20x10.5 +29 (4" lip) Nitto NT555 265/35/20
not even with spacers?
Maya/Trafficstar RT5 20x9/10.5
The bolt circle is not compatible, No way! You will not even be able to present it in place. It needs to be 5 X 130, and you can get the equivalent of less offset with spacers you can not add offset. You need more offset in front and back.
There are other turbo style wheels that will fit the Cayman without spacers in eBay. Make sure you ask how much they weight. They could be heavy.
1 - 9 of 9 Posts
