Newbie with some questions.
Results 1 to 17 of 17
Thread: Newbie with some questions.
    Mar 2016
    Oxford, UK
    Hi all,
    First off... Hello! I'm Greg, an aircraft engineer from Oxfordshire and I've just collected my 2011 Cayman (2.9l) in Carrara White, I'm absolutely loving it! I have lots of subtle modifications that I'd like to make, however, I am seeking some advice on certain tasks.
    So the get started, having come from a 2013 Mercedes C-Class coupe with all the bells and whistles, I'm missing certain features... In particular, the excellent headlights. I appreciate the fact that Mercedes headlights are brighter than the sun, but they do make driving at night much more pleasurable, so I'd like to upgrade from the dull yellow standard units in my Cayman. I am wondering if I will require a full "HID" kit or just the replacement D1S bulbs to a higher Kelvin (K) temperature?
    Secondly, the LED strips adjacent to the front fogs... Is there an option to make them daytime running lights? Would this require a software tweak at a dealership or more likely to require a wiring modification?
    Finally, I find the manual gearbox linkages rather loud and ever so slightly sloppy, so I'm looking at installing a short-shift'ing mechanism. What are your thoughts? I will be installing myself, if you have any tips on doing the job from past experience, please share!
    Any advice is most appreciated.
    Regards,
    Greg.
    Dec 2013
    1,493
    318
    596
    Re: Newbie with some questions.
    Welcome Gregory!
    I'm not sure about the lighting but here's a DIY for a 987.2 Boxster: Porsche 987 Short Shift Kit DIY Guide Imagine it's identical if not very similar in a Cayman.
    As for the rest, I'm clueless but here's what a quick search gave me: https://www.planet-9.com/987-cayman-a...?highlight=acg (More here: https://goo.gl/DiQ3J5)
    And another search query for the LED strips: https://goo.gl/BND0im
    This needs to be in the 987 mods section so it'll get a wider audience. C'mon chows, K-man isn't paying..oh wait.
    2.7L Standard Cayman. Standard Transmission. Standard 18" Wheels. Standard Lights. 2-way Sports+ Seats. Almost Standard. Awesomeness. Standard.
    May 2008
    IN
    2,428
    40
    Welcome. You don't mention if your car currently has halogens or HID. If halogens you'll need the full kit as the ballasts etc aren't there for HID lamps. I've read more than a few posts on problems with the aftermarket kits so do your homework first. Don't know if you can get OEM retrofit or not. Dealer question I'd imagine.
    As to DRL's I've been seeing threads with folks wanting to turn them off here on the 981's. Don't think they've had luck yet. If you have PCM you could try going through the menus. Maybe get lucky. Otherwise try the dealer. It's probably code able via PIWIS but you need the tech that knows where the setting is hidden.
    The short shifter should tighten things up but will not change the noise. I think you'll find the car rather more visceral than Mercedes. Probably notice all kinds of noises that you aren't used to hearing. It's a feature. Part of the experience.
    Forgot to mention another potential issue with an HID retrofit if you currently have halogens. The retrofit won't have the auto height adjustment that HID's have and halogens typically don't. Can create a glare problem for oncoming traffic.
    Les
    Sep 2014
    South Wales
    1,392
    376
    300
    Welcome Greg. I can't help with your questions, but there is plenty of good advice to be had on here.
    Mar 2016
    Oxford, UK
    Quote Originally Posted by Caymeown View Post
    Welcome Gregory!
    Thanks Caymeown! Plenty of useful photo's in those links!
    Quote Originally Posted by Greywolf View Post
    Thanks Greywolf, to clarify... I have the Halogen units and I've just purchased an HID kit (5000K) which should be with me later in the week, I'll let you know how I get on.
    Regarding the DRL mod, I'm thinking about splicing an ignition switched live to the +ve supply wire to the LED units, however I'd like to incorporate a relay, fuse and resistor in there somewhere... I'll have to ask the electricary wizards at work what would work best.
    I'm becoming used to the noise and after reading the owners manual, it is completely normal. I didn't realise that Porsche recommend pull away in 2nd gear when on flat, level ground!
    Quote Originally Posted by Trev450 View Post
    Cheers Trev!
    Jan 2010
    3,062
    54
    Quote Originally Posted by gregdaisley View Post
    Congrats on the car. You'll have lots to learn about Porsche's' eccentricity. Uhmmm - I mean features.
    I don't think you have the above right. I've never heard of this being recommended for a manual unless driving on ice. Maybe that is referring to PDK in manual mode?
    34,347
    1777
    3219
    5472
    274
    Welcome Gregory!
    Short shift kit may or may not eliminate your noise, you can always pull the center console and drive around trying to pinpoint where the noise is coming from to see if something just needs lubed or something is rubbing where it shouldn't etc.
    Lighting - you will need entire HID kit, ballasts, etc. and there are write-ups on this site from owners who have done this, be sure to check Articles section. As mentioned, you won't have self leveling though.
    You mention an LED strip. On a 2011 987.2 Cayman there is no LED strip, there is only the round fog lights so I'm not sure what you want to turn into a DRL. There is a setting in PIWIS to turn the round fog lights into DRLs or not, a dealer can activate/de-activate this setting. If you have some other LED strip please post pics because only Boxsters had an LED strip in 2011 whereas the Cayman had round fogs.
    What am I not paying attention to?
    My Garage | My Gallery | My Articles | My Blog | My Classifieds
    K-Man S
    Save on a new Tesla using my code: http://ts.la/ken5051
    Jun 2015
    NJ
    For HID make sure you avoid morimotos. They will most likely flicker and throw an error even with the Canbus kit. When you ask them about it they will just tell you oh this is not really plug and play. Matt is a big porsche guy and the only fix he found was to go get your car coded for xenon.
    The kit that works and proves Matt's theory to be BS is MTEC Xenon HID Conversion Kit Mercedes Benz W212 E Class
    I installed them and they were plug and play. No errors and no flickering. A bit pricier but hey it works
    Mar 2016
    Oxford, UK
    Quote Originally Posted by RSchwerer View Post
    Newbie with some questions.-img_3831-jpg
    http://i1238.photobucket.com/albums/ff489/gregdaisley/IMG_3831_zpsxb2sfdzx.jpg
    These are the lights in question, factory fitted to 987.2 cars in the UK...
    Newbie with some questions.-fullsizerender-jpg
    http://s1238.photobucket.com/user/gregdaisley/media/FullSizeRender_zpsosshvai2.jpg.html
    Quote Originally Posted by fosingwo View Post
    Thanks, I have ordered a kit from HIDS-Direct here in the UK so I'll keep you posted with my progress and whether they work or not...
    Jan 2008
    828
    49
    It won't be dark where you are anymore after you see the light.
    Augie
    34,347
    1777
    3219
    5472
    274
    Oops yeah forgot about those mini strips I thought you were talking Boxster style so nevermind. I'd still check to see if dealer can make DRL changes in the piwis to them and let us know.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    K-Man S
    Jan 2010
    3,062
    54
    That's odd - there's nothing remotely like that recommendation in the US manual.
    Newbie with some questions.-shiftinggears-jpg
    No wonder some people are wearing-out clutches in 50K miles. IMO, that's nonsense. This is a sports car, not an econo-box. "Launching" in 2nd sure is going to hurt performance and add to clutch wear. Not worth saving little money on fuel.
    Jan 2010
    3,062
    54
    On the 987,2, I don't think the LED strips are bright enough to legally qualify as DRL. The newer cars (Porsches, Audis, Jags...) have much brighter LED strips.
    Dec 2014
    Malaysia
    1,382
    455
    215
    you're right, the lights are not very bright but are used as position lights and parking lights at night.
    I recall somewhere in some cases they are used as driving lights when the round 4 dice DRL is not activated.
    on mine, the DRL can be turned on/off using the dash "stalk" on the steering column, but there is no option to use the smaller lights instead.
    Mar 2016
    Oxford, UK
    So I installed my HID kit yesterday afternoon and took the car a drive after the sun went down. The difference was night and day, pardon the pun! Haha.
    For anyone interested, this is the kit I purchased from HIDS-Direct (UK Based)...
    [img]Terminator_HID_kit_1__94282.1417434998.1280.1280.j pg[/img]
    Mar 2016
    Oxford, UK
    Just ordered my short-shift kit from Design911, hopefully it'll arrived in time for the weekend!
    Sep 2014
    South Wales
    1,392
    376
    300
    Like the sound of the mods you're doing, Greg. I've dealt with Design 911 on a number of occasions and always found them to despatch orders promptly.
  20. Remove Advertisements
  1. fist post with some questions and pics
    By roofis303 in forum 987 Cayman and Boxster Problems and Complaints
    Last Post: 06-05-2013, 06:13 AM
  2. Newbie with a question!
    By nickl630 in forum 987 Cayman and Boxster Electronics
    Last Post: 02-27-2011, 08:37 PM
  3. Question Newbie with a question
    By Nervous in forum 987 Cayman and Boxster Chat
    Last Post: 10-24-2008, 06:24 AM
  4. New Poster with some questions
    By Tobizach in forum 987 Cayman and Boxster Service and Tech
    Last Post: 09-01-2007, 07:58 PM
  5. New Owner!! (with some questions)
    By Karrera4 in forum 987 Cayman and Boxster Chat
    Last Post: 08-19-2007, 06:51 PM
