Subject line says it all - been using aftermarket LED tail lights for about 10 years. Think they're DRC style from memory.
I honestly don't know how long the problem has been happening, a neighbor mentioned it the other day!
It's only the left side assembly, and ONLY the white reverse lights.
Everything else works great.
I had a couple of spare canbus decoder units (long story), and I tried the problematic assembly with 3 separate canbus units and same problem each time.
I'm not sure if it has something to do with the rear backup camera I installed a while back, since that is activated when reverse is engaged?
I'm using one of those cheap Android head units that look identical to the factory had unit, with of course much more functionality.
I can't seem to find any way to disable the rear backup camera, and I honestly can't recall if I did anything special to set it up other than splice to the correct wire below the driver's seat?
Could this flickering be caused by the rear backup camera or is it likely to be either a simple case of a failing assembly or perhaps something to do with the main Porsche coding to provide the correct voltage for the LEDs since the car had the regular old school tail light assembly and I've never had Porsche or an independent 3rd party do anything to the car?
I'm afraid to waste nearly $1000 on a new set of LED tail lights if the problem wasn't the assembly and instead something like voltage?
And similarly have the dealer hit me with a large bill and find nothing!
It's a 20 year old car with 90K miles in terrific condition and it's really just used for nice days if I feel like going through some twisty roads!
Appreciate any advice, guidance (how to disable the rear backup camera without tearing up the wiring), and ideas on what is likely going on.
Cheers!
Cheers!
