Have an issue with battery drain while car off, asleep and unlocked. I am providing my diagnostics that identified the following results, and my conclusion as to source of problem, but I have no idea what a solution could be:
1) After car goes 'to sleep" (dash displays blank out) there is are rhythmic relay clicking sounds repeating every 10-15 seconds.
2) Loudest is coming from frunk area. Less loud just behind instrument cluster, and also from engine compartment. Dash clicks first, then immediately followed by clicks in frunk and engine area.
3) I checked current draw using clamp on amp meter at battery. Read .90 to 1.5 amps draw when no clicking going on. When click occurs (10-15 seconds apart) current draw spikes up to 4-7 amp draw, then fades back down to base reading. I concluded this is what is killing battery.
Testing and troubleshooting to locate parasitic draw:
1) Replaced battery with identical specs stock AGM to see if low voltage was an issue. Drove car to confirm charging properly. Validated charging and voltage with antigravity lead acid battery monitor (very handy cheap item). Charging fine and proper voltage.
2) After car entered sleep mode, measured amp draw again, started removing fuses from left fuse box.
3) When I hit fuse B5 (fuel pump) loud clicking stopped from frunk area, but clicking was still heard from instrument cluster and engine compartment.
4) Amp draw declined significantly, but still above reasonable levels for car in sleep mode (reading .9 to 1.5 amps when clicking)
5) When B9 (instrument cluster) fuse pulled, all clicking stopped. Amp draw down to a steady .70ma. Overnight battery voltage did not change at all. Stayed at 100% per antigravity historic tracking.
6) Replaced B5 (fuel pump circuit) fuse, with B9 instrument cluster still removed. No clicking heard and left another day. Zero drop again. Seems B5 may not be the main issue, but downstream triggered from B9 instrument cluster clicking activity which was stopped by pulling B9 fuse.
7) To test this out, left out B5 and put back in B9. Clicking from instrument cluster and engine compartment restarted again, but because B5 fuse was out (much higher amperage fuse) amp draw was still occurring when clicks heard, but at a much lower level. Battery was draining, but not as fast. Left unattended, this would eventually kill battery.
My conclusion: Instrument cluster circuit is triggering a relay that is cascading to the fuel pump relay, causing a compounded amp draw (possibly it is the priming of the injectors happening every 15 seconds?)
Leaving out B9 cluster fuse when engine off, causes battery to show no measurable voltage drop over 24 hours. Reinstalling fuse causes drain to reoccur. Car runs fine and no symptoms when running, just when off.
Any experts out there that has any insight as to what this could be? I had seen a much older posting with a very similar complaint, but no meaningful replies returned.
