What did the factory do to get 340HP in the GTS instead of 325HP with the same 3.4 engine? Can it be done to the lower HP engine in a mon GTS?
NOTICE - Before adding photos to posts on Planet-9, please review: Posting Photos on Planet-9
The throttle is only restricted at higher RPMs, it's fully open lower down. This has been datalogged by people many times. The same engine in the 911 isn't entirely comparable because it does have slightly different hardware there. Larger throttle body, different plenum, headers and exhaust system.Also don't forget the same 3.4L motor made 350HP on the base 911, so it makes from 315 to 350. The throttle-plate restriction makes sense, but I'd like to know if that's it, or if there's something more. What is strange is the 315HP Boxster has peak HP at 6,700 rpm, while my 340 GTS at 7,400. If only the throttle plate was restricted, it'd reach the peak at close to the same rpm IMO
