Here's what I know from oservation and experience watching my body man replace my hood and front bumper at 2000 miles.
1. my 07 CS was originally delivered with a slight discrepancy of the bumper-leading edge of the hood. I was satisfied with the explanations as given elsewhere in this thread.
2. But I looked at about five Caymans and CSs in the dealer's lot and noted that there was no consistency in the alignment. Some hood edges were even, some were below as you have noted. Some did not look like they were installed with great care to this point. (Note: this so-called intentional gap feature may be more like an accident of fabrication or assembly)
3. When the hood/leading edge was seen as even, some of those cars also appeared to have the gapping of the lateral hood raised (uneven). (Note: this suggests that if the front edge is adjusted even, the lateral edges might be uneven, supporting the intentional design theory expressed in this thread.
4. When my new hood was installed by the body shop, I noted the front edge was even and the left lateral hood edge raised. I call this to the attention of the body man and he simply adjusted the center latch height and the rubber stops left and right. In the end, in order to get the new hood looking correct on the right side, the front of the hood appeared to be lowered a bit below the bumper trailing edge. I've settled for this for now.
Last thoughts: I don't believe that Porsche has the fit and look of the hood right; having the gapping uneven on one edge and even on the other just doesn't make sense to me (allowing what others have said to the contrary). If this was an intentional thing, all of the cars would uniformly display this feature, and not all do if you look at several cars at once. I may have my body man re-visit this situation, and if I do, I'll report on it here.
