Just finished installing my A129 Duo, not terribly happy with my work and if I had to do it over again I'd have a pro do it. The front camera was little trouble, mainly getting the cable around the top of the A pillar and into the dash took only a few special words of encouragement. The rear camera in this product has a very thick round cable that caused trouble along the small side window, I could not get it tucked in, so threw in the towel and used a clip up high on the glass. I ran the excess cable all around the weatherstripping in the trunk and mounted the camera high on the back window. Only a little cable is visible. Could have used two cable installation tools at times but made do with what I had.
I am powering mine with a "EasyAcc 20000mAh Portable Charger Fast Recharge Power Bank with 4A 2-Port Input 4.8A Smart Output High Capacity External Battery Pack" via Amazon. It sits in the glovebox and I will plug it into the car as needed to recharge or bring it in the house.
Should I get another camera in the future I would either make sure the cables are thinner or pay a pro to do it. Btw some pros will allow you to buy your own camera and they will charge for the install. Might be worth it unless you really want to tackle it yourself. Maybe Porsche could see fit to have an optional overly expensive system, maybe with upgradeable cameras?
