Ugh... ran over a tree branch or something... should I be worried?
1 reading
49K views 6 replies 5 participants last post by  Rockster
#1 ·
It was raining and was going over a hill... as soon as I reached the apex, there was something square in the middle of the road that I had no choice but to run it over. I heard this awful scraping and think it was a big tree branch. All seemed fine with the car but when I pulled into the driveway, I heard a scraping noise on the tire. When I look under the car, it seems as if there is a plastic shield that was knocked out of place. Should I be worried?
#4 ·
Its a piece of plastic that looks like it fit the curve of the wheel well but is now malformed. I was having a hard time getting under the car to see better. It sounds like its rubbing against the tire when I turn the steering wheel all the way to get into the garage. It never made the sound before.
#5 ·
There are some plastic air ducts that sit below the body line. They direct air to your disk brakes. They sit an inch or two out in the open. Chances are you broke one or both of them. Nothing to worry about as long as you get them back into position. Assess the damage. You may need to cut some of the broken marterial off and insert a metal screw or two to hold them in place. You'll need to get your car up on jack stands to inspect and do the surgery.
#7 ·
The (thankfully) few times I've encountered road debris with no obvious serious damage (hitting a tire carcass late one night on 50 highway west of Strong City KS busted the driver's side radiator and it was obvious from the cloud of water vapor the damage was serious) I like to have the Porsche techs inspect the car for any less obvious signs of damage. A plastic panel loose or cracked is one thing, but in the case of a muffler that bangs its way down the length of the car I'd like to make sure no tire was cut, that no lines were smashed and there was no collateral damage to anything under the car.
Once I hit something -- I was in my Turbo -- not too far from home but it was on a Saturday and I knew the Porsche dealer was closed but I also knew of a close by BMW dealer and on a hunch drove there and its service department was open.
I spoke to the BMW SM about what happened and asked if he would put the car on a lift and inspect the car along with me. 'course I offered to pay for this.
The SM said sure and in a few minutes the car was in the air and the SM and a senior BMW tech and I were under the car. We traced the path the debris took under the car and spotted no damage of any consequence. Back on the ground I asked the SM to put together a invoice and he said "no charge" and that was that.
