Hey folks,
I just added the Kenwood KSC-SW1 subwoofer to my sound-package plus car, and it REEEAAAALLLLYYY fills in the bass at higher volumes when the stock system turns the bass down. Install took about and hour and a half, though more than half of that was just removing the headunit. The subwoofer has some really great features, 1) it's powered so you don't have to have a separate amplifier installed and buy an enclosure, 2) it's a 150 watt amplifier RMS and has uses a passive radiatior design with two 6.25'' cones much like the Infinity Basslink, and 3) It has a handy remote for making on-the-fly adjustments and 4) It's less than 4'' deep and fits perfectly behind either seat! The manual says use the headunits power source (the sub draws 8 amps), but instead I used a fuse tap into the fuse for the Ask amplifier, Bose amplfier, and Bose subwoofer. Since the ASK amplifier only draws 10 amps and this sub only draws 8, that should leave me with a good safety threshold. Then I spliced into speaker level inputs\outputs coming from the headunit and going to the rear speakers. For $140 total cost ($130 subwoofer, 5 dollars splices from radio shack, and 5 dollars T30 and T20 torx screw drivers), it's a mod that I would heavily reccomend to those with the standard sound system. Now I just gotta get the sucker pinned down
- Suneet
- Suneet
