Hello, I'm new to this forum, but have posted on the ******** thread "start loving you Bose". I'm in the process of swapping out all (4) of my base speakers to Burmester and adding the two 4" mids in the door along with the identical 4" mids in the rear of my 981C. To drive everything I'm adding an amp (more on that later).
I purchased the Burmester AMT (ribbon tweeter) per the excellent feedback in the above mentioned thread. I tested them out and they really sound amazing! ** It's important to note that both the Base system and Bose have a small capacitor / bass blocker on the tweeters to block the low frequencies.... So if you're thinking about doing this mod, or upgrading to another tweeter, make sure you use an appropriate capacitor / passive filter on them!
In the interest of keeping everything the same as the Burmester setup - I took the plunge and ordered the Burmester version of the air vents which cover the tweeters (note these had to be special ordered from Germany and took about 7 weeks to my door)! Well - I just received the vents and I'm a little disappointed by them as I don't think they were worth the cost (and wait). As you can see, they only differ from the existing vent in that they don't have the square (with circular tweeter holder) plate attached (glued) to them. I could have fairly easily modified the existing vents by removing this plate (see Red arrow). Secondarily, I also purchased and tested the Rear Burmester tweeter, which sound great and are a worth wile upgrade (and cheap in comparison) at a little over $120/pair...They are 1" (compared to .75" of Base and Bose) and they sound really good and would have just dropped right in the existing vent! Note these also would need a capacitor as Burmester runs active crossovers in their system which has been confirmed. Here are some pics...Let me know if anyone has any questions and I'll post more findings later.
