A simple or maybe not so simple question. Is the stock tire size stagger for 18" CS optimal for balanced handeling? Since the tires are the ultimate arbiter of traction, what is the best solution for maximum cornering power?
I've read many threads that seem to indicate that the car is set up to understeer from the factory for safety on the street. Is this a function of tire pressure / sway bar settings or is the car purposely under tired in the front?
If it is under tired in front would'nt it make sense to only increase the tire size in front to make the car more neutral & improve braking? ( DE Track use) It would also require less "tuning" with the sway bars as well.
Your thoughts on this would be appreciated
