Pot calling the kettle black?
Yes, somewhat tongue in cheek... maybe a little taste of one's own medicine. ;-)
It doesn't mean I am an idiot with more money than common sense.
No, in fact... that's how many of us came to be in a position to own a Porsche in the first place.
In the case of exhaust - it's just a couple of pieces of pipe, in that sense it's not rocket science.
While appearing rather simple in function, both intake and exhaust side science has evolved highly, as engines come from the factory with very high specific outputs. The "max" flow possible thought process of a decade ago, or specific to turbos, goes out the window. There are many considerations, such as torque vs. top HP, resonance, drone, etc... but I get your point.
Fact is: cat-backs on a 987.2 will add sound more than power. I would put them in the same category as de-snork and air filter. If we want to nitpick they will offer a slight measurable gain if put on a dyno. But the only noticeable gain will be the sound increase. Which most of us will falsely interpret as making (substantially) more power. If that was "truth", then why not just unbolt the exhaust alltogether - it should make the most power since it makes more sound?
I agree that the cat-back on a 987.2 is less useful than a 987.1 vehicle, no doubt. However, as a vehicle is tuned more and more above stock, every little piece matters. Thebob effectively said it does NO good whatsoever, and that's inaccurate, or at best, a guess and personal opinion. In fact, in another thread on the Cayman R, he actually touted the increased exhaust piping size of the R?!? Can't have your cake and eat it, too.
When you add a canned tune, you will effectively get a Cayman R base file with e-gas tweaks to get a quicker response when pressing the pedal to the right. To expect 360HP from this is, well, remarkable.
I disagree. Maybe similar in function and parameters altered, but it's not a Cayman R file. If it were that simple, how would Softronic offered a tune file for years before the Cayman R even came out? And it strongly seems, by independent dyno, that the new Softronic 93 octane file mentioned gets ~345-350 on a tune alone. Maybe a few more HP with a cat-back. It might just be, that at that state of tune, it was found that the cat-back section could add a little more flow and power. But Thebob immediately disagreed, with no data to back it up... while simultaneously asking Softronic for data, who had just posted and referred to dynos done at a 3rd party shop, for a customer that I don't think Softronic even knew was dynoing the car.
TheBob's point about the 991 Carrera is that Porsche had to add some mechanical parts to make that kind of power with the same exact engine. AND a tune. If they could just alter the tune, don't you think they would have walked down that more cost effective path instead?
Yes, but no - that's not why they did it. Quite the opposite. The 991 uses the same airbox, filter assembly for all models and engine sizes. In order for that intake structure to mate up to all engines, they needed the same size (larger) throttle body as the other engines. In doing so, they didn't need the resonance flap anymore. So yes, it was for cost savings, and simplified assembly on the line. Porsche receives the airbox, filter, intake assembly as one piece... ready to just pop in the car on the line... no matter the engine size. This keeps it simple, and also parts count lower. But... the actual downpipes from the plenum to the intakes, is the same size as the 987.2 engine. In related news, the 991 now uses all the same header section across all engine models - reduced parts count and easier assembly again. The reason they don't use the 987.2 headers on the 991, is because the exhaust would point the wrong direction in the 991.
Let's not forget... there's a reason that Porsche is the most profitable car company out there. ;-)
They are doing it with the 981 GTS (340HP). So I don't think that logic is invalid.
Because all the parts are pretty much the same from CS to CGTS, so then this goes back to the question of if Porsche can get this power out of a GTS with just a remap, why can't a 987.2?
It's always important to remember that Porsche makes cars NOT the best they can be, but for perfect product placement for maximum profit. And in the Cayman, that meant holding it back from the 911. We all know this.
:cheers:
