No vent tube on 2015 AGM battery?
6.6K views 6 replies 5 participants last post by  MidEngine-Fan
#1 ·
In doing a bit of battery self-tutorial, I took a closer look at the OEM battery in my 2015 Cayman (has auto start/stop). The battery is made by Banner in Austria (but it looks a lot like the old Moll case style - except the area where the acid "fill" ports would be on the Moll is here plastered over with labels). I assume that this is an AGM battery due to the stress of the start/stop (which I always have off anyway). The Banner website says to never open the fill ports on the AGM battery (duh).
My one real question is: am I seeing straight that the AGM battery has no venting system? No signs of the venting tube like on my 987.2, and the vent ports on the battery seem to be plugged. I guess the AGM does not need to be vented?
Anyone with a late model 981 see the same absence of the battery venting tube?
#2 ·
The AGM battery on my 2016 Cayman has no vent either. They don't need vents, but it's possible that due to old regulations, batteries inside the vehicle could require one, even with AGMs. The only car I know of with battery inside the cabin is mid-engine Ferraris, but last one I checked was a 2006, with a factory wet-cell, and it did have a vent. Since 2008 they have AGMs, but haven't been in there (you need to remove the passenger foot kick-plate to access it). I don't think the frunk on our cars and trunk on Corvettes classify as 'inside the cabin', but who knows.
#3 ·
Thank you for the confirmation. I've been trying to understand AGM/not and vent tube/not. Searches brought out some contradictory information (as usual). Nice to hear from someone who actually knows, rather than from someone who just has an "opinion".
#4 ·
I thought that a feature of AGM was that the battery could be used in any orientation. Upside down, on end, etc. One of the earlier uses was boating - and they were advertised to work immersed in water (probably not a good long-term idea since water is a weak conductor).
So for the above reasons, a vent could allow a leak and/or contamination.
#5 ·
What was confusing me was that the AGM battery casing still has the same vent port openings near each terminal, albeit they are plugged up and unused. I suspect that the OEM battery supplier is using the identical battery casing for AGM or not, with different guts and the redundant holes blocked off.
#6 ·
AGM are sealed units, utilizing gel and fiberglass.
I would guess that the vent tube posts are just for holders of legacy vent tubes, to keep them in place. If you went back to a lead acid battery, you'd need them.
After a dozen AGM batteries on motorcycles and snowmobiles, I will use them on my Cayman when the time comes.
#7 ·
That's what I've heard. I love AGM, have an Odyssey AGM in the 914.
