Hi all-
I just finished an oil change on my "new-to-me" 2010 Cayman S. Everything went well, until I checked the oil and realized I had overfilled. I've done hundreds of oil changes, and have never overfilled.
Here's my question:
I used Rhino ramps in the rear only, so it was sloping forward. I ONLY added 7qts of oil to get my initial reading. Apparently, 7qts put me over the top/max fill line! I'm now wondering if lifting the rear of the car, caused oil to remain in the front of the oil pan, preventing a full drain.
Thoughts? I plan to remove some of the oil (since I'm prepping for a track day), but thought I'd get your input. Yes, I did change the filter. I also let the oil drain for a good 20-30min after I pulled the drain plug. Seems odd that I'm overfilled after adding only 7qts.
Thanks!
Here's my question:
Thanks!
