61 - 71 of 71 Posts
hey one thing, it talks about Car+tuner buttons to enter the green service menu, my car does not have the tuner button as far as I can see, but source or media, also my buttons are the haptic ones, and cannot seem to use these to enter the green menu.
Do you have the physical buttons in yours? See image below, of mine, with the Red button Car enabled
Found pressing centre nob and source takes you to Green menu, centre nob and media takes you to Red menu! See here for chap doing it
Ok, assume you unzipped the files as is to root of SD card?
I will try this afternoon, after 4 or 5pm UK time.
I will first try the AIO install, then once that's done, will try the maps update, will let you know how it goes, it is quite a large update at 14GB
So Android Auto back up and working. Same as you get spinning Searching for Updates with Map update.
Will try a few things this evening and will post if i find a way
I was able to update UK maps using the Online option!! I am still trying to figure out updating using the patch, as I would like some other countries, and the online update will only allow up to 3, and UK takes up 2
I have another type of question.
I have '17 Macan GTS with PCM 4.0 from US market. PCM is "updated" by use of some kind of MHI2_ER_POG11_K3299 firmware.
Green menu is also different, because it have "localization" made by some local shop (in Poland).
In this case I have two questions:
  • Could I install M.i.B without any issues to actual firmware? Could it affect in any way to actual state of PCM?
  • Could I update my PCM with some AOI firmware?
Unit works as it should. CarPlay works, I don't have working Porsche Connect or Porsche Track Precision app (WiFi onboard).
Only thing which is not working are RadioStation icons. I've tried to updated RadioDB and Gracenote, but without success (I mean - it was installed, but not change appearance at all).
I have a related question, since the PCM pictured above is like mine (no DVD drive). Is it possible to now, or in the future, to update the firmware of my '25 PCM (without nav) myself? I do have an X431 CRP919X Elite scanner if needed. Thank you.
61 - 71 of 71 Posts
