On a roll this weekend with minor projects on the car. Thought I would check the air filters. I'm at 20K and thinking about changing them.
I won't go into details on removing the trim, there is a really detailed guide already on the site here:
http://www.planet-9.com/981-diy-discussion/103195-look-new-article-981-engine-cover-removal.html
But you just need to remove:
Left and right carpet inserts.
Left and right suspension mount covers.
Water/Oil horizontal trim piece
Rear Firewall Carpet Pad (vertical).
I made up those names, but they will make more sense with pics.
This is the right carpet insert in my car. It just pulls out from the top.
This is the right suspension mount cover. Best to have a nice wide trim removal tool for this.
Next is the horizontal trim bar that the oil and water openings are found. This can be pulled off with just your hands.
Last piece of trim is the thick and fairly heavy carpet pad on the firewall. It pulls out easily. I just pull from the center and set aside someplace very clean.
I had already examined my left (drivers) side air filter a few days ago. This is showing the more complicated right/passenger side filter removal. Note the grey pad protecting an ECU unit. Just pull it out and put aside.
The driver's side filter is visible on the left. The passenger's side filter is behind the ECU.
