I have been searching to replace the Bose 8" woofers on huge door cavities, and found a slim/shallow 8" 4 ohm woofers by Focal, IS200, $200 a pair (comes with ok tweeters, caps on all speakers). Mounting depth on these woofers is only 2 1/2", so with the windows down, they fit in just fine. I had to custom make the MDF brackets/baffles by local shop for $80/pair. Tweeters, I used Ciare CT250 (proven to my ears from $12K system), 4 ohm, shipped from Italy for $140, attached bass blocking caps $10. If you get 1" tweeters, you can fit them into existing grills with very minor fabrication. Total $430.
Tweeters match Bose 4 ohm impedance, but woofers 1 ohm to 4 ohm which can result in noticeable volume decrease. However, Focal with traditional woofer construction, unlike from Burmester and Bose's ultra shallow bracket with paper cone, Focal actually sounded remarkably better with clean punch and fairy deep low end extension. With PCM sound setting set to base gain and tweeter decrease, I was able to balance the volume effectively. I am quite satisfied with this minor modification, no more fatiguing from Bose booms and cheap high-ends.
I listened to Burmester, although it was clearly better than the Bose, but I believe you get better SQ out of aftermarket speakers. If anyone is interested, I will take the door panels apart and post pictures.
