So, I recently installed the IPD intake plenum on my 986 Boxster ('02 2.7L). While the 986 has seemingly always lacked much availability for aftermarket parts compared to what's available for the other models & generations for the other Porsche siblings, this was a mod that I've always wanted to try out.
PART1: Here we go:
Here is the OEM throttle body and plastic T style plenum next to the upgraded larger throttle body and IPD Y style plenum, along with the clamps and silicone reducers.
Smooth Y design of the plenum, rubber sealing O-ring to mate to the larger throttle body.
The Cayman 3.4L IPD plenum is modified for the 986 eGas boxster models.
I believe the modifications for the 986 fitment (compared to stock for the Cayman application) is this larger nipple, and machined back piece.
Here is a comparison of the stock boxster 69mm throttle body next to the upgraded 75mm throttle body. (For simplicity sake, I'll refer to these as 69mm and 75mm, although the actual dimensions measured accurately are more along the lines of 68.xx mm and 74.xx mm). The larger "75mm" throttle body comes on the NA 996 Carreras, 987 Boxster & Cayman, 997TT, 997 NA, etc.
OEM T-pipe removed and new IPD silicone reducers set on the oem intake manifolds.
"Modified" Cayman S IPD silicone hose (cayman hose coupled to another hose via tube for temporary setup)
More to come...
PART1: Here we go:
More to come...
