41 - 60 of 173 Posts
I tried following the instructions to install this PIWIS but ran into an installation problem. Everything went fine until step 5. It tries to run/install the .ova file, and after about 1 minute, I get an error that it failed to import appliance. It shows a Result Code: E_INVALIDARG (0x80070057). Anyone know why it would do this? I tried twice with the same result.
Discussion starter · #43 ·
Have a look at the thread on trouble shooting. Link below. Look at the second post.
Thanks for the tip. I tried it, but no dice. However, It turned out that I was a bit short on disk space. Instructions say you need 20GB, but that does not include the initial file download. I freed up space and I got it installed and running. Now I will play with it and see if it does enough for me to warrant the cable purchase.
Examples of hardware you will need. You don’t need a hard drive with the software loaded, which they will most likely try and sell you as well. I bought the obd2.market cable and it works a treat, and the quality seems to be very good. If you told me it came from Porsche I would believe you.
https://www.xcar360.com/porsche-piwis-tester-ii-vci-box.html
Piwis 2 Tester for Porsche
This is amazing!
I've got VirtualBox and downloaded the .ova file, though haven't installed it yet.
To make sure I understand the hardware I need for this, is it just a cable or cables or is it one of the HCI box/interface units (but without software) and cables?
EDIT: this is an issue with my Host/Manjaro. Everything worked first try in about 5 minutes including importing the VM on a Windows 10 Host. Thank you.
Hello,
I have the XP VM imported and running in Virtualbox 6.1.12 on Manjaro Linux 20. Kernel 5.7. Guest Editions CD downloaded (not needed) extension pack 6.1.12 (needed). The XP VM boots and I can access all menus and use the PIWIS2 software in simulation.
After verifying the VM image and software functions I ordered a VCI. Powers on from the car great and semtec device is detected by Linux (dmesg -w when plug). Here is the order I am using:
1. Car ignition on (tried started engine as well)
2. Plug VCI to OBD port (powers on)
3. 15 sec wait, plug VCI USB port on Manjaro Host laptop
4. dmesg -w detects the device no errors
5. (with filter applied for semtec) boot VM.
6. VM mounts the VCI and detects it under Device Manager on boot (usb host controller drivers were taken care of on initial import/use)
7. Launch PIWIS2 -> Diagnostics -> 911 -> 997.
8. Diag window opens: 99010: diagnostic system could not be initialised. 99011 Comm. module not connected. Please check.
9. I retry with F8 multiple times and either receive the same message indefinitely OR it pops the progress window 'applying firmware (3.3.2 I believe) to VCI'
10. Once it applies firmware and 'resets the VCI' it just disconnects and won't reconnect. (I manually re connect it via 'Devices' in VBox and press F8 again.
11. (loop steps 9->10). I cannot get past these 'not found' or 'applying firmware' steps.
I have performed the imprint steps again in the software with the VCI connected (and without) no change. I have tried USB 1.1/2.0 and 3.0 (doesnt work native XP id have to patch in some drivers for that). I have disconnected and reconnected it at least 20-30 times in various combinations and have closed/reopened the software (through task manager) before/after 'firmware updates' etc, and it can never recognize the unit to poll the car.
If it 'applies the firmware' (which i don't believe is completing because it keeps repeating it..) and 'disconnects' and I hit F8 it will load the next screen and say unable to verify model 997 please check, and when i scan the avail modules none are highlighted/show any info. I'm surprised it 'goes through' like this as it obviously doesnt detect the VCI/car at that point, but that's the furthest I have gotten as far as screens go.
On the host:
With USB 1.1 selected I get: Process <PID> (USBDevIo--1) called USBDEVFS_CLEAR_HALT for active endpoint <hex address>. 6x when I press F8 and it attempts to communicate. (solid USB light, blinking pwr).
With 2.0 selected I get: vboxdrv messages as it detects it (VBoxEhciR0.r0 being the most relevant here I'd assume) and then when it tries to communicate (F8) it pops reset high-speed USB device number <#> using xhci_hcd.
3.0 (xhci) isnt supported/wont mount or anything in XP.
Looks like my host is having an issue 'downgrading' the native usb3 bus to 2 (ehci) for some reason? vbox ehci proxy/version issue? I think it is failing to 'reset' after the firmware update which is why it never takes and can never communicate. I have tried various linux kernels/host additions and vbox versions. all seem to exhibit the same issue of not communicating or finishing firmware updates.
TLDR: VCI 'reset' after seemingly mandatory 'firmware update' doesn't seem to complete from inside the VM, issue resetting on host?
Any help would be appreciated. I unfortunately don't have an old laptop around otherwise I'd just install the VM image straight to bare metal and negate the VM translations all together. May still be the way I end up going.
Thank you for reading.
If you get the black menu bar as described by Rob997 above, here is the way to fix it:
When testing on another machine I had loaded this on last year, this is what I discovered.
When you start the PIWIS, if you have entered 'x' as the validationstring then the 'validity of imprint' will be blank. However, if you have entered a number, eg 9999, this number will count down as time progresses. Look at the screenshot from OnetimeCS above where the validity is 9575 days.
I noted on my machine that when I opened PIWIS (I had put in 9999 days last year) and the imprint was invalid, the validity of imprint was blank. There was also a message saying the imprint was invalid. Instead of reloading the entire VM, I imprinted it again as per the instructions below without having to import the PIWIS.ova file again into Virtualbox. If I exited out of PIWIS without doing the imprint again I ended up with the problem that Rob997 describes above that only seems to be solved by deleting the PIWIS VM from Virtualbox and then importing again.
My advice is to look at the validity of imprint when you open PIWIS each time to check it's still valid. If not, immediately go and imprint again. If you don't it seems that you will get the black menu bar when you open PIWIS again. I have made a text file of the imprint instructions and shared it with the PIWIS VM so I can immediately refer to it when required.
Imprint Instructions:
1. Open PIWIS 2
2. Go to -- SETTINGS--> Tester Imprint
3. Go to "Licence" tab - if you are unable to enter a key (boxes greyed out), go to "KEY" tab and click 'Create Key' (will generate a requirement code), and then go back to "Licence" tab
4. Enter any key and press save, keep repeating it until it says "too many faulty attempts"
5. go to "KEY" tab and click 'Create Key' (will generate a requirement code)
6. Exit PIWIS II with task manager. To exit PIWIS without shutting down the VM, right click on taskbar (at bottom), open task manager, then go to 'desktop' and end task.
7. Go to the folder "c:\user data" and locate the file "praegung.xml" (this is the 'praegung.xml' on the desktop) edit it with notepad and locate the part "demand key", delete the existing number and enter 4032546358 to replace the one in the file - save the file and close.
8. Start the piwis again, Go to -- SETTINGS--> Tester Imprint in the "KEY" tab you should see the key you have entered before.
9. go to "license" tab and enter the key below and click SAVE. This is the same key that is in the licence.txt file on the desktop that can be copy/pasted into the key.
s3nT IfSX sytP rDFo 1TRM Gw==
10. Now it should say "Tester was succesfully imprinted" and validity should show 30 days. Close PIWIS with task manager.
11. Go to the folder (use the shortcut on the desktop) "c:\user data" and locate the file "praegung.xml" edit it with notepad and locate the part "validationstring" replace the 30 by unlimited OR enter "X" number of days (eg-9999)
I follow what you are saying, but I don’t see a save button.
quoting myself again. any difference in which piwis i get?
I purchased mine at www.obdii.shop/. It works great and received it in 4 days. I initially placed an order with obd2market, but the tester was confiscated in customs and obd2market would not send me a new one or refund my money until I filed a claim with PayPal.
One thing to consider is if you want the wlan feature that eliminates the need for a usb cable. That WiFi feature will add about $50 to the price. I purchased mine for $465 all in.
I have already coded both my Porsches for options I wanted, but didn’t want to take to the dealer. So, the tester has already paid for itself.
Thank you ill look at obdii.shop, it's odd that customs held your tester. did they ever say why?
They never admitted that testers that have the Porsche logo on cover are subject to be confiscated because of intellectual property rights.
obdii told me this, and their tester only says PIWIS 2 on it because they had problems in the past when they included the Porsche logo.
They are pretty easy to deal with and answered all my questions before I purchased.
makes sense. thanks for the tip
What options did you code if don't mind me asking?
Tempted to pick one up too as would love to have sports+/rev matching on my '14 6-speed and from what I've read seems like it is possible to enable with this.
Where did you read that? That feature was part of Sports Chrono package and in order to enable that, it required a special "activation code" from Porsche which some russian supposedly can generate at a cost of $120, but still requires the button for programming, etc.
It was either on here or ******** don't recall which thread exactly but but I do recall at least a couple different members mentioned they enabled it successfully and yes they had to get an activation code and maybe even center console switch to add sports plus button.
